Hard top strikers
ok i've noticed on the highway that i can hear wind noise between the top and the windsheild. I searched on here first and found that i should replace the strikers with Hard top ones. i've looked at pics on a site and the ones i have look to be the same. The one thing i noticed was that where the locking pin, locks onto the striker, it looks to be worn or chipped. what i really need is pics of what the striker looks like brand new or close to brand new and have something to compare mine with. I may order new ones but not to sure if i should. I've looked at all the searched ones and can't find any pics of them. oh yeah i have a 01 S. Please help me out. i can't stand the noise.
Doesn't matter if they're hardtop strikers or not, they will eventually wear down, just slower maybe. As a quick fix, you can swap the two from side to side. The wear on the striker is usually on one side of the latch point. By swapping them, you give the latch a fresh area.
after looking at some more posts i noticed a post that had strikers that were worn alot like mine and he said that he replaced the strikers with new ones and it helped alot. I think i'm going to end up doing it anyways.
a cheap trick that you might want to try first:
i just bought some of that air hose that is used in fish tanks and cut a very small piece and put it over the finger of the top latch hook... tightened it up nicely, was a very easy install and also cheap!
I just got my hard top strikers from hard top guy and they are totally different then whats in the car now. i'm going to install them tomorrow seeing its to dark now. i'm deff going to shop from hard top guy too cause i ordered them on tuesday and got them thurs. now if i only had money i'd buy gears.
figures you guys would ask to see the old strikers after i threw them away. theres a post on here that i found that shows the old strikers that mine looked like. i'll try to find it and post pics. it helped alot esp. on the highway above 80MPH.
here are pics of old and new strikers.
the outer strikers are old ones and the new hard top one is the middle one. will also notice that the new striker middle part has a smaller area.
