Hardtopr removal
Originally Posted by jshimer23' date='Jan 19 2009, 02:47 PM
Very easy indeed. You undo the front latches like you do the soft top. Then pull the front latches forward and then it lifts right off.
It goes back on just as easy.
It goes on/off in less than 2 minutes with a helping hand.
Levi
Yeah, you can take it off by yourself, you can even put it on by yourself. Some guys have hoists mounted in the garage, and I did too, in my old house, but I haven't bothered to put it back up since I moved. A bicycle hoist from target plus a bent pipe, a hook, and a few straps are all you need. Lots of pictures on here if you search.
Some tips for doing it yourself:
Put something on the HT posts so you don't have to worry about the paint (I use drilled nylon balls, but you could use anything).
Take your shoes off so you don't have to worry about stepping on the seat.
Don't do it in public. You'll look like a dork.
