Having a PITA getting the exhaust nuts removed
Old Aug 19, 2003 | 06:59 PM
Quik S2K's Avatar
Default Having a PITA getting the exhaust nuts removed
I am trying to remove my stock exhaust and the 3 bolts are killing me. I have loostened them all the way and tehy come to the end of the bolt but get extremely tight. WD-40 wont even budge them. The bolt looks like it was hammered on the end to prevent the nuts from falling off. I was able to get one off but the other 2 wont even budge. even woth going back and forth.
How did you guys get them off? I'm thinking of having a shop do it but I would rather do it myself if I can. Anyone?? Help!!!
Old Aug 19, 2003 | 07:02 PM
fly_S2K's Avatar
I think you may have crossthreaded them. That happened to one of mine and my buddies bolts while removing the exhaust as well. I just unscrewed the bolt while using pliers to pull on the bolt to get it off the stud. I'm not sure if that helps much.
-Johnny
Old Aug 19, 2003 | 07:05 PM
pfb's Avatar
pfb
If you haven't munged the nuts up yet, run them back up the stud, then use the proper size die to recut the stud threads...
Old Aug 19, 2003 | 07:06 PM
djkojione's Avatar
you should take it to a shop. i agree with fly_s2k, you probably crossthreaded them. no good. it just happend to me awhile ago, but its an easy fix. just remember, if its beginning to get a lil hard to get off, stop and take it somewhere.
Old Aug 19, 2003 | 07:07 PM
Quik S2K's Avatar
Actually I looked at that. They arent crossthreaded but the bolt gets wider at the tip and prevents the nut from coming off. It looked like Honda stamped the center of the threaded bolt to widen it for some reason. I know sometimes they do this to keep the nut from falling off, but this is redicilous!!!
Old Aug 19, 2003 | 07:09 PM
Quik S2K's Avatar
Yeah, thats what I figured. I bolted everything back up and plan on taking it down and let someone else do it. That way if they mess it up, they are responsable. I just am afraid to leave my baby in the hands of someone else. He's still new!!!
Old Aug 19, 2003 | 07:12 PM
speed4tu's Avatar
If you have access to an impact wrench, that will do it. If not, try tapping your ratchet/wrench with a hammer.
martin j
Jul 10, 2016 11:15 PM
SMG1990
Mar 17, 2016 02:13 PM
tom275
Jul 23, 2014 06:26 AM
StuS2k
Apr 4, 2014 09:48 AM
wysongca
Apr 21, 2009 06:32 PM
