Headlight Help Needed
Old Sep 4, 2003 | 05:44 AM
AustinS2k2003's Avatar
Default Headlight Help Needed
I cleared my headlights months ago - no leakage or anything which is good. I discovered that the drivers side headlight seems to have a missing/loose connection because when the parking lights are on (one turn on the stick) that one doesn't illuminate. It also doesn't flash when the alarm it disarmed/armed. Fortunately when using the turn signal it does work. There are 4 connections on the headlight housing (if I remember right). Which one is problematic and is there an easy way to check/fix this connection WITHOUT removing the front bumper? I'll take the bumper off if I have to but I would really prefer to TRY and fix this without having to remove the bumper first. Suggestions? Ideas? I know its rather cramped in there for sure so any help is appreciated. If you could maybe post a diagram of which connection is messed up too that'd help
Old Sep 4, 2003 | 07:17 AM
No one out there?
Old Sep 4, 2003 | 09:07 AM
3ngin33r1's Avatar
You can get in there without pulling the bumper, but it's a b!tch and can hurt.
Almost sounds like your bulb is bad.
Old Sep 4, 2003 | 09:10 AM
I highly doubt it is the bulb because the turn signal works just fine and I believe that the turn signal utilizes the same bulb as the parking / running lamps / alarm diarm/arm flash. Correct me if I am wrong.
-B
Old Sep 4, 2003 | 09:17 AM
rateds2k's Avatar
Turn the wheel all the way to one side. Use a flat screwdriver to remove the two clips. You will be able to pull down the shield enough to change either bulb.
Old Sep 4, 2003 | 09:18 AM
3ngin33r1's Avatar
The turn signal is not the same bulb (if I remember right) as the running lights.
Old Sep 4, 2003 | 09:27 AM
[QUOTE]Originally posted by rateds2k
[B]Turn the wheel all the way to one side.
Old Sep 4, 2003 | 11:05 AM
rateds2k's Avatar
The turn signal bulbs are a 7440 and the parking bulbs are 194
The two clips are in the black shield. One is right on the underside of the fender and the other is about 4 inches in on the shield. They are blach and the size of a nickel.
LightKiosk
May 2, 2013 10:11 AM
pnp
Sep 6, 2008 08:57 PM
StevenH
Oct 30, 2001 02:38 PM
S2k Dude
Jun 11, 2001 02:04 PM
