Heat from rear wheel well
Old May 24, 2001 | 05:57 AM
David's Avatar
Have you guys noticed how much heat comes out of the rear wheel well after a drive --its much more than from the front wheel well. Is it just the proximity to the mufflers? I went for a short drive around the neighborhood last night and when I came back in the garage and walked around the car I noticed a real difference between the front and the rear. Is it my imagination?
Old May 24, 2001 | 06:44 AM
Brett's Avatar
This also happened with my 911, although I always attributed it to the proxmity of the rear wheels to the engine in that car. I don't know why this would be so in the S.
Old May 24, 2001 | 08:19 AM
lvs2k's Avatar
Yes.
Old May 24, 2001 | 09:02 AM
S2000 Owner's Avatar
A. Rear end can get hot, remember it's limit slip and has clutches in it.
B. Go ahead and touch those rotors --- they are in excess of 500 degrees --- unless you coast to all stops.
Old May 24, 2001 | 09:14 AM
David's Avatar
That's why I expected more heat from the front wheel well.
Old May 24, 2001 | 09:49 AM
Silver S2K's Avatar
Check your tire pressure. Too low a pressure in your rear tires could cause them to heat up more than usual. There was a noticeable cooling of the rear wheel well area after I corrected my tire pressures (up from 25 psi).
Old May 24, 2001 | 01:25 PM
mns2k's Avatar
Could it be the exhaust?
Cody Red
Houstook Swap Meet
Aug 31, 2014 10:37 PM
Cody Red
For Sale
Aug 31, 2014 10:36 PM
siplergsr
Nov 3, 2012 09:19 PM
eg9
Aug 25, 2012 12:18 AM
