Heat under Center Console
Old Oct 14, 2006 | 01:50 PM
_ChriS2K_'s Avatar
Default Heat under Center Console
I've had my S for about a month now and sometimes i notice quite a bit of heat coming from around my cupholder area, ebrake, area, and the shifter itself is warm. It happens every now and then and sometimes i dont even notice any heat. I was wondering if something is wrong or is it normal to have heat coming from the center. It feels like the heater is on low when it happens.
My S is an 02 with ap2 center console if that matters. 42k miles. I chanegd all fluids including tranny fluid at 40k. Any advice would help. Thanks
Old Oct 14, 2006 | 03:00 PM
centralcoastbuc's Avatar
Normal transmission heat.
Old Oct 14, 2006 | 03:08 PM
coxjajb's Avatar
Same on my 02.
Old Oct 14, 2006 | 05:20 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
If you look very carefully,you should find a tranny,underneath the console.
Old Oct 14, 2006 | 06:36 PM
Ek9's Avatar
Ek9
Banned
I'd be willing to bet that most of the heat comes from the exhaust pipes which also run under there. The transmission should probably never see the high side of 200 degrees F which really isn't that hot.
Old Oct 14, 2006 | 08:29 PM
Cycloneranga's Avatar
I used to think the heat came from the transmission, and maybe some of it does. However, after unbolting my exhaust just behind the cat for a night of obnoxiously loud fun, I realized it is probably the exhaust because on that night it got REALLY hot around the console.
Old Oct 14, 2006 | 09:44 PM
Antonov's Avatar
Old Oct 14, 2006 | 10:33 PM
_ChriS2K_'s Avatar
k koo.....then i dont have to worry. Hehe Thanks
Old Oct 15, 2006 | 01:05 AM
jakub2000's Avatar
Nothing to worry.
You should touch mine with a 3" turbo-heated pipe under it.
Old Oct 15, 2006 | 03:20 PM
guardiase's Avatar
And to think Honda put the cupholder on there.
