HELP!!!
Old Dec 25, 2000 | 08:43 AM
Y2K1S2K's Avatar
i just was waxing my S2K and i noticed a pretty big scratch in the paint! i dont know where it came from...how do i get rid of it?!?! HELP!
Old Dec 25, 2000 | 08:54 AM
cthree's Avatar
Administrator
Damn already?!?!
It's likely just the clear coat that is scratched. It can probably be wetsanded and buffed out. Check with a quality paint and body shop. I wouldn't attempt it myself for fear of making it worse. If the base coat is scratched (you can see the metal/primer) then that's a problem that will require paint be put back on. If the scratch is white then it's the clear coat and can be sanded out and fixed without painting.
Cheers and Merry Christmas!
Old Dec 25, 2000 | 09:01 AM
Y2K1S2K's Avatar
its not that bad...i think its just the clearcoat...is there any polish or anything that can just buff it out?
Old Dec 25, 2000 | 09:09 AM
cthree's Avatar
Administrator
You can use a fine rubbing compound or a fine grit wet-paper like 800+ grit. I would start with the finest grit you can find like 1200 first and only go courser if you must. Do it by hand, keep it plenty wet and rub in a back and forth motion, not circular. It will take some serious elbow grease. Don't become impatient or you will scuff the paint and dull it. Just work the scratch back and forth applying lots of water and don't press to hard.
I should point out that you are not removing the scratch, just smoothing the edges of it so it doesn't reflect the light. It will be there you just will have a hard time seeing it. I offer no guarantees or warranty. Do at your own risk.
[This message has been edited by cthree (edited December 25, 2000).]
Old Dec 25, 2000 | 09:21 AM
Y2K1S2K's Avatar
There arent any good polishes or scratch removers i can use? the idea of using sandpaper on my car scares me...
Old Dec 25, 2000 | 09:51 AM
dbw's Avatar
dbw
try toothpaste first..[apply with a damp rag and buff with a clean dry one..no paper towels please!]..it will often remove shallow scratches....also your car will smell minty sweet!
Old Dec 25, 2000 | 09:55 AM
Y2K1S2K's Avatar
ok...what kind of toothpaste...i ask this because i have this baking soda and peroxide stuff...i dont want it to react with my paint or anything...
Old Dec 25, 2000 | 10:26 AM
Aft3rburn's Avatar
Hey cthree,
just in case others are wanting to use this mothod of wet sanding, in what direction do you sand? With (or parallel) or perpendicular to the scratch?
Old Dec 25, 2000 | 10:50 AM
cthree's Avatar
Administrator
[QUOTE]Originally posted by Aft3rburn:
[B]Hey cthree,
Old Dec 25, 2000 | 11:11 AM
YoungS2K's Avatar
Try ScratchOut (a yellow bottle) u can get it at most auto store.
Cthree:
Do you have any clue how to get the wax off the convertable top? I was waxing the car and some wax got on to the conv' top. Can't seem to take it out with water.
NICK
