Help me I.D this noise
I have this strange noise coming from my car. I've had it from day one.
When I back my car out of the driveway, into the street. I put the car into first gear, take off slowly & when I've traveled about 100 feet I hear a "clunk" sound.
- This only happens the first time I drive the car each day.
- It dosent matter what gear I'm in (first 100 feet I'm either in 1st or 2nd).
- There seems to be no problem with the car, just the cluck noise.
Any thoughts? Thanks in advance.
Clunk, ie, deep metallic sound...or click? The one click when first starting in the day is usually the hub axle nuts that need to be re-torqued. They should be torqued to 220ft-lb. If the click remains, then grease the axle splines. If one doesn't fix the click, the other usually does.
The sound almost sounds like a big spring being released.
Maybe a hub axle nut you say? I'm not sure what the hub axle nut is. Is it the large nut you see when you remove the back wheel? Do you think the dealership would check this for free since the car is under warentee?
Standard VSA system check? All '06 and later cars have VSA and do this right after forward movement (usually within the first 100 ft). Are you sure it only happens once a day and not each time you get in it? Its usually easily missed unless you are listening closely for it.
