Help me with my Exhaust!
Old Oct 23, 2006 | 08:12 PM
krazyguy316's Avatar
Default Help me with my Exhaust!
Ok guys i got the single 3inch lovefab exhaust. You know the bar that goes across the bottom that we need to take out to remove the stock exhaust system? I cant put it back in because the piping is in the way. My questions is, do we need the bar there? Plus the exhaust piping is rubbing up again the right ride of the metal piece where the bar bolts up too. How do i fix this problem?
Old Oct 23, 2006 | 09:50 PM
Mike'S2K's Avatar
I think You should get the HKS exhaust its the best one i think if you want great sound but if you want a lot of HP dont even bother because it will only give you like 5whp i think.
Old Oct 23, 2006 | 09:56 PM
Series10's Avatar
no problem, just drive with the bar off and the piping bumping for a few days. Then, this weekend, take your car to a local exhaust shop and have them adjust your hangers a little bit. Should do the trick.
Old Oct 23, 2006 | 10:55 PM
i try to push the piping up a little and it look like its about to hit the axle. So i dont know if it can be fix. hmm ill have to contact the guy i got it from to see wat he did. sounds great thouhg =)
Old Oct 24, 2006 | 01:20 AM
SIIK2NR's Avatar
That bar is a brace and is to reduce flex on the rear of the car. I would recommend that you get it moddified to be on the car. If you fabricate a bar that will allow the the exhaust to pass through to the rear, I would do that. Shouldn't be much of a project.
Tim
Old Oct 24, 2006 | 11:02 AM
yea i just got the hangers bent and now it sits in a better position but still no way to put that bar on. hmm anyone got lovefabs number? probably gona have to talk to cory and see wat he did.
Old Oct 24, 2006 | 12:02 PM
s2kshift9k's Avatar
are N/A running a 3in?
Old Oct 24, 2006 | 12:48 PM
Pawan's Avatar
I am, for now, until I go turbo. I dynoed the car. Gain a bit almost everywhere (no power loss). Mine was custom made using true mandrel bent sections from the test pipe back w/ a bullet resonator and Apexi world sport 80mm muffler. Very tight fit . We used 2 washers for the bar that krazyguy316 talked about to lowered it down a bit and cleared everything beautifully.
As for the sound, very unique and I love it. For normal driving, gets really deep between 3000 and 3500 rpm (bit loud). Very quite when cruising below 3000 rpm and above 4k (highway speed). WOT after vtec, gets really loud like a race car and very unique. My friends all give .
Old Oct 24, 2006 | 12:54 PM
Pawan's Avatar
Right now I'm using 63mm (2 1/2") test pipe and really want to get a 70mm. That should help my top end even more. Next I'll get EMS that will allow me to tweak the timing. With the kind of flow i'm getting now, timing will help substantially.
Old Oct 24, 2006 | 06:59 PM
hey bro can you show me some picutres of your washer so i can go get it. I really want to put that bar back on. What kind of washer is it? As for about the sound your talking about. It is very unique, even though its a bit loud but i still love the sound it gives off lol. I will get a video of what i am talking about pretty soon up so you can se what i mean =)
