Help Needed S2K Purchase
Old May 28, 2024 | 09:44 AM
ALPHARAND's Avatar
Question Help Needed S2K Purchase
Hello guys
I'm new to this forum... I just came from Mexico to the US (Orange County CA) due to work and now I have the possibility of buying a S2K.
my budget is no more than 20k, as I want this to be my project car (I intend to keep the car forever). I was looking for some cars and I found one that is for sale at 16k, 2002 AP1 silver no mods everything stock, clean title 208,000 miles looking at the Carfax report it had 7 previous owners and 3 minor accidents. it was just smog tested and registered here in CA according to the Carfax report in the past month.
is this a good price or should I look for something else? Also, what is the process of buying the car from a private seller I have the cash but what should I get from the seller to register the car under my Name. I paid for a Carfax report attached her for better car background.
Old May 28, 2024 | 10:28 AM
Chuck S's Avatar
Photos will help and many cars here have had higher reported mileage but keep in mind these engines are not rebuildable with any success. . Frequent oil changes are a good sign although it's unlikely the S2000-specific and correct oil filter (an article of faith here) was ever used by Jiffy Lube et al.
In addition to normal maintenance the car will probably require a replacement roof and tires at a minimum, perhaps suspension components and air conditioning.
Even if everything is mechanically, structurally, and cosmetically sound it will remain a 200,000+ mile car with all the liabilities.
-- Chuck
Old May 28, 2024 | 03:14 PM
ALPHARAND's Avatar
My bad here are all the pictures i got
Old May 28, 2024 | 05:43 PM
B serious's Avatar
Man, California pricing is crazy. I think that's like a $12K car anywhere else in the country.
Try offering the person $12K and see what they say. There are a lot of miles on that car and some damage. So its going to need some maintenance.
The process of buying a used car is slightly different everywhere in the US. However, its almost always your responsibility to register the car if you're buying from a private party. Typically, you buy the vehicle, the seller hands over a signed title, and then go to the DMV to pay the taxes and registration fees.
Find out if the seller has the title in hand. If the car still has a loan on it, the bank has the title. The process in this case is a little bit more complex, but nothing that's impossible.
Old May 28, 2024 | 06:02 PM
Bullwings's Avatar
If it didn't have the 3 accidents, it could be a maybe. That said, it has accidents. It's also modified - exhaust and suspension (you can see the tophats in the engine bay). Fenders appear to be stock and un-rolled, so that's a plus. Anyway, I'd say pass at $16K - i'm with B-Serious, $12k.
Someone said it, if you can't afford a relatively clean version of a used car, you can't afford a more used and well worn version of that car. The amount of time, money, and effort that it takes to get a beat up car to the same condition as one that's well maintained will likely cost equal or more.
If your budget is $20K, there are other examples that I have seen pop up that are better options than this one. Good luck with your search - be patient.
Old May 29, 2024 | 09:22 AM
ALPHARAND's Avatar
offered 12k he said he can do $14,500 (-$1,500).. lol
Old May 29, 2024 | 09:45 AM
Bullwings's Avatar
Its it a full - true California car - hasn't seen time in the Rust-Belt area of the US?
Also, ask if he's willing to do a pre-purchase inspection or at the very least, a compression test.
This shop is in OC - my go to shop. https://formula-s.net/
Could be worth while at that price, if everything else checks out - no/minimal rust (true california car), and compression numbers check out.
Old May 29, 2024 | 06:02 PM
garoto's Avatar
He went down $5500 just like that! That driver side fender looks like the S2000 badge isn't aligned, which means the VIN is probably not on there. If he can do $14500, he can do $13000. $13000 MAX and not a dime more. Or you're out. Trust and believe that he'll sell. He. Will.
Old Jun 1, 2024 | 10:05 PM
ALPHARAND's Avatar
oh, the car was listed for 16k, so he went down only $1500, not $5,500 . he didn't want to do vehicle inspection... so that turned me down maybe 12k I would take the risk without inspection
Old Jun 2, 2024 | 04:53 AM
Dibsen's Avatar
these cars are awesome so it’s hard to let one go. In this case, I think it’s wise you keep looking. You should be able to find the S of your dreams for $20k
