help- wet sanding messed up paint!
I attempted to fix a paint chip by wet sanding with 1500 grit sandpaper after using the touch-up paint. Then i polished. However, the wet-sanding left a dull area around the touch-up area. I used Zaino polish. Should I have used another polish? How do I get rid of the dull areas.
I thought this was supposed to be easy like many of you on here say it is.
First try using any kind of car wax first. If that doesn't do it, try Turtle wax "light" rubbing compound.
You can find that at any Wal-mart, Pep Boys, etc. About $2.00. It's a light rubbing compound and WILL NOT scratch your finish and gets most scratches/haze out. This really works wonders. When you are done, follow-up with normal wax over the area.
If it's down super deep, it won't get that out and will most likely need repainting, or a touch-up stick so it's not that noticeable.
You can find that at any Wal-mart, Pep Boys, etc. About $2.00. It's a light rubbing compound and WILL NOT scratch your finish and gets most scratches/haze out. This really works wonders. When you are done, follow-up with normal wax over the area. If it's down super deep, it won't get that out and will most likely need repainting, or a touch-up stick so it's not that noticeable.
