High flow cat
Old Feb 20, 2006 | 12:59 PM
9kscream's Avatar
Default High flow cat
A friend of mine has a G35 and replaced two of his four cats with "high flow catalytic converters" are these available for the S2K ... all is see is talk about test pipes... if these are the only option... what kind of HP gains are people seeing?
I have HKS exhaust and AEM V2 intake just FYI.
Old Feb 20, 2006 | 01:23 PM
sahtt's Avatar
I believe the car has high-flow like catalytic converters stock, hence the jump straight to test pipes for power increases.
Old Feb 20, 2006 | 01:48 PM
S2kracka's Avatar
Yup, stock is a nice high-flow unit. An upgrade would be a testpipe.
Old Feb 20, 2006 | 02:00 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
You already have a high flow cat.
Old Feb 20, 2006 | 02:13 PM
9kscream's Avatar
ok then... next question... what kind of gains can i expect from a test pipe and is there a significant noise increase??
Old Feb 20, 2006 | 02:59 PM
gain +/- 3 WHP,slight noise increase,no drone.
Old Feb 20, 2006 | 03:22 PM
sahtt's Avatar
The 3-5whp gain is magnified as you build on your exhaust system. Once you have a quality header and cat-back, the test pipe will probably gain closer to 6-8whp in theory compared to the stock unit.
Old Feb 20, 2006 | 03:26 PM
Optimistic.!!!
Old Feb 20, 2006 | 03:58 PM
Wildncrazy's Avatar
Random Technologies does make a high flow cat for our car. It is a 4" model. I sent them my cat and we found out that it flowed as well as any they had in production so they made one that flowed more.
If you want to keep your car street legal Random is the only real option I know. By real I mean tested to actually flow more than stock.
Old Feb 20, 2006 | 04:30 PM
WalkingDrunken's Avatar
There is an old old post, probably two years old at least, that had numbers testing both our stock cat and other aftermarket high flow cats. Our cat outflowed all highflow cats and equalled random technology. I'll try to search for it but I can't use the search function very sucessfully.
