Hit side walk and axle
Old Nov 30, 2015 | 06:07 PM
Couna777's Avatar
Banned
Default Hit side walk and axle
So I know I shouldn't have gone driving crazy on a rainy day
But during the circle intersection i sped up little bit
And the car spun and front passenger side wheel hit the sidewalk not too hard but not too gently
After I got out side of road, didn't notice any damage to the car thank god
But after I ve been driving for awhile I noticed that my wheel was not centered when I was driving straight
And I got outside once again checked wheel after getting my handle straight, it seemed like my wheel was like / | instead of | |(parallel)
It was not significantly noticeable by very little
Now I am worried that if I bent the axle and maybe I'll have to change whole axle for this ?
Or it could be adjustable without any exchanging axle ?
Or just simply get alignment ??
Did anyone had a experience like this ??
Help please !
Old Dec 1, 2015 | 03:21 AM
Chuck S's Avatar
These always start like this...
I'd get it professionally checked and fixed.
-- Chuck
Old Dec 2, 2015 | 06:20 PM
rob-2's Avatar
How is it you structure your sentences in this format?
Old Dec 3, 2015 | 01:35 AM
zdave87's Avatar
Member
He's a poet
And doesn't even know it.
Old Dec 3, 2015 | 06:42 AM
mongomery1234's Avatar
I honestly never understand these threads.. If you hit something and you think something is wrong then why havnt you already made an appointment to have a professional check it out instead of posting on a forum asking for someone's opinion who isn't even with the vehicle. Things like this are impossible to diagnose with a post it needs to be on a rack with someone who knows what they are doing checking it out/repairing the problem.
Old Dec 3, 2015 | 10:17 AM
Car Analogy's Avatar
Something is bent. An alignment is not going to fix it. Hopefully its just stuff that is easy to replace, like a control arm, or spindle, and not something like bent subframe.
Sent from my SM-G920P using IB AutoGroup
Old Dec 3, 2015 | 10:41 AM
mixwell's Avatar
it's apparent that you don't know much about suspension/steering. take it to someone that does.
Old Dec 3, 2015 | 11:16 AM
RedCelica's Avatar
I vote new control arm...they're always the first to go in these situations.
Old Dec 3, 2015 | 12:00 PM
zeroptzero's Avatar
If your wheel is now \\ , when it used to be [] , then yeah you have a problem.
As Brett (RedCelica) said it is most likely a control arm. Alternatively, if you end up with a broken ball joint that can cause some serious issues that can leave you stranded on the side of the road or in a ditch. Get it checked asap.
Old Dec 3, 2015 | 12:07 PM
SmokeyGatto's Avatar
get it fixed, and try your luck in a parking lot next time
