Hole in soft top!
Old Mar 8, 2010 | 11:16 AM
TheRook's Avatar
Default Hole in soft top!
Hey all, I've had a tear about 2inches long in my top that was previously patched by the original owner. Looks like what he did was just put a patch on the inside and some silicone or something on the outside. Well the patch finally came off and now its time for me to do something new about it.
I plan on sewing the the hole together using a baseball stitch which I got out of an old aircraft maintenance book. After stitching, I was going to glue a patch on the inside and put silicone on the outside of the stitches to prevent any water coming through. So what do you guys think?
Old Mar 8, 2010 | 11:22 AM
BearNVa's Avatar
I would just sew it tightly and sew the patch to it from underneath...
Old Mar 8, 2010 | 11:27 AM
suzuka-blue-s2k's Avatar
I have a small tear in my top in the spot everyone gets them. I just used some black thread, sewed it, and then put some fabric glue on the inside of it. It hasnt leaked any water or anything.
Old Mar 8, 2010 | 11:34 AM
TheRook's Avatar
So does it look like the thread is wearing at all from the outside or the top is wearing any around the stitches?
BearNVa I don't want to put extra stitches if i can help it.
Old Mar 8, 2010 | 11:37 AM
energetic's Avatar
My suggestion is to read the following link.
Vinyl top tear repair
Old Mar 8, 2010 | 11:50 AM
Mike21's Avatar
sew it up. get one of those iron-on patches. apply it on the inside w/ a long bbq lighter.
Old Mar 8, 2010 | 11:54 AM
TheRook's Avatar
energetic thats a great link, I think that would have been perfect if it was the first time it tore cause I'm having trouble cleaning off the left over silicone but i think i will take a lot of ideas from that especially with the iron-on patch.
Mike21 did you really use a bbq lighter?
Old Mar 8, 2010 | 03:53 PM
Hollowman's Avatar
What I did wass to sew a patch of top material to the underside and stiched through both.. Hasn't torn or let water leak in.. I tried to just sew another place but without the patch and it tore again.. It needs the reinforcement.. I haven't tried the iron patch but I thnk it would just peel off in a short time if you drop your top from time to time.. My patched one has held up vey well and I drop the top when I get the chance and here in SO Cal I get to do that quite often..
Saving for a new top but I'll be patching it up until then..
Old Mar 8, 2010 | 04:06 PM
Well so far my thread has stayed there and isnt worn. I know every once in a while it will wear out and probably take 10 minutes to sew it back up.
Old Mar 9, 2010 | 06:33 AM
Mike21's Avatar
yup. no way in hell i was gonna fit an iron in there. i sewed up the holes that form behind the windows. put a patch on it, torched it, and pressed it on. this was about 4 months ago. still holding up like a champ.
those iron-on patches work with heat.
