How bad is this?
After hearing people on the board talk about there dual HKS HI-power exhausts have two resonators I decided to check out mine. I jacked the car up and was shocked to see I had one honda muffler
probably where one resonator goes. The other side of the stock exhaust looks like it was capped off. One pipe is going toward the other side and just looked capped. The rest of the exhaust has just the Y pipe and two HKS Hi Power mufflers. What a big surprise because all this time I thought I had a true HKS. I think it even sounds pretty good like the other HKS exhaust sound clips running around.
Can I just have a straight pipe put on where the honda muffler is? What else can I do besides getting a whole new exhaust.
http://videos.streetfire.net/video/1f53cea...854003e2abf.htm
Here is a sound clip of my exhaust now. Not the greatest quality but gives you an idea how it sounds. It is a bit deeper driver around. This vid is with the test pipe and header.
probably where one resonator goes. The other side of the stock exhaust looks like it was capped off. One pipe is going toward the other side and just looked capped. The rest of the exhaust has just the Y pipe and two HKS Hi Power mufflers. What a big surprise because all this time I thought I had a true HKS. I think it even sounds pretty good like the other HKS exhaust sound clips running around. Can I just have a straight pipe put on where the honda muffler is? What else can I do besides getting a whole new exhaust.
Originally Posted by bighead2,Apr 26 2007, 04:52 PM
you never looked under your car before?
April Fools?
April Fools?
It is like they left all the original piping and muffler, on the right side after the test pipe.
I won't be able to snap pics until this weekend.
Translation: "I got an OEM exhaust except for two HKS N1 mufflers from the axle back"
Explanation: The "capped off" part is the Helmholtz resonator. You're probably putting down as much WHP as a full cat back HKS system. If you're happy with the sound, leave it be.
Well said my friend. So I should not be losing any power with the extra muffler in the middle? I am pretty happy with the sound just wondered what would happen if I put a straight pipe in place of the honda muffler? Any performance gains or major change in sound?Thanks for the translation.
Originally Posted by JackS,Apr 26 2007, 05:13 PM
I agree. Leave it as is. This is no doubt a "custom" job which could be as good or better than full HKS. After all it does appear someone went tthrough the extra expense to have this done.
You are not going to see any gains from swapping exhausts...unless you go to a single exhaust....and then, most of the gain in performance will be due to less weight....if you are happy with the sound, that is all that matters...
