How do I get these on!
Old Mar 16, 2006 | 11:49 AM
Vladimir L's Avatar
Default How do I get these on!
I would drive over to a shop to remove em but my car wont run till next week. I want to get them off righ tnow. Damn Muteki lugs!
Old Mar 16, 2006 | 11:50 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
WD40.or a big bar,
Old Mar 16, 2006 | 11:57 AM
bighead's Avatar
I hate it when my nuts get jamed!
Old Mar 16, 2006 | 11:59 AM
Vladimir L's Avatar
I hate it too
Muteki lug wrench is so cheap it breaks! I broken two of them. I ordered new spoon lugs but I still have to remove the old ones.
aronparsons's Avatar
Use a breaker bar or use an impact wrench. You want to "snap" the bolts loose; just pulling is not going to work. Also, be sure to use anti-seize on the bolts next time and torque to the proper specification. Over-tightening the lugnuts can also lead to warping your rotors due to uneven pressure.
Old Mar 16, 2006 | 12:10 PM
Vladimir L's Avatar
The hard part is getting the bar or wrench in there since they are tuner lugs and ultra small hole....it has volks on right now
Old Mar 16, 2006 | 03:44 PM
vtec9's Avatar
I use a big bar with a copper pipe over the end when I have a stuck lug. Then I try to unseize it with a quick jerk to snap it free. If you end up stripping the lug, you need to pound on a smaller socket with a hammer and continue.
Old Mar 16, 2006 | 03:58 PM
Vladimir L's Avatar
I'm just gonna buy an air tool and drill it out. Then return it the next day.
Old Mar 16, 2006 | 04:11 PM
steve c's Avatar
Why?
Hammer or foot + wrench will do just fine. Shock force for the win.
By the way, left is loose.
S2000GT's Avatar
Big FookingHammer
good luck and hope you dont snap your studs in the process - be careful
