How do I get through the firewall?
I would go through were the Cruise control feeds into the car. Its located near the middle (a little above) of the firewall towards the drivers side of the car (near the clutch master cylinder and resovoirs)(sp)
Good Luck!
Good Luck!
I say driver's side, up fairly high and behind the hard lines you'll see there.
Very visible, very easy to get to inside the car as well. I walked to work today so I can't snap a photo. Go check the electronics section and see where the power wires are run through.
Originally Posted by S2KMiyo,Feb 20 2008, 01:34 PM
*sigh*
I suck.
I suck.
1) Stand next to the driver side fender, next to the firewall.
2) If parked in a dark area, aim flashlight down at under-the-hood side of firewall.
3) about 6 inches from the fender in front of you, you will see this large black grommet.
4) Shake you head a couple times and come back to post about how you "can't believe it was right there the whole time!"
If you're still stuck tonight, PM me or post back in here and I'll take a picture for you.
