how do u reset check engine light. for those with the manual
Old Jan 17, 2004 | 01:13 AM
shiaochiu's Avatar
Default how do u reset check engine light. for those with the manual
Car just randomly threw a Check engine light after I put the stock intake back in... should i be worried? how do i reset it?
Thanks
Old Jan 17, 2004 | 03:55 AM
wortham's Avatar
yep. always worry about a check engine light. here's what you should do.
go to autozone have them pull the code
look up the code in your helms (aka S2000 bible )
fix the code
hug your beautiful car
a common error you can run into when it comes to putting the stock air box back in is P0411. your car is trying to tell you that you routed a vacuum hose incorrectly somewhere or you didn't tighten the hoses down enough causing a link or there's a leak in one of your hoses. you should double check your work to include the hoses on the hard line by your engine, the air box and solenoid and the little black box deal that's near the solenoid. you might also want to check that small, white check valve that's near the black box. it's supposed to be facing a certain way. do a search on the boards for the above code for a pic.
and to reset the ECU, it's the third fuse slot down on your right bank. remember. third fuse SLOT not third fuse.
Old Jan 17, 2004 | 07:57 AM
3ngin33r1's Avatar
Read the FAQ note at the top of this forum...
Old Jan 17, 2004 | 08:16 AM
wortham's Avatar
that too.
just about every question you can imagine has been asked and answered on the boards. it'll save you the time of posting it and waiting for a response if you do a search. the search function on this boards does a hell of a job finding what you want.
Old Jan 17, 2004 | 09:26 AM
shiaochiu's Avatar
Hey thanks for your help guys!
btw..where is the faq? . its not in the library > common questions section?
Old Jan 17, 2004 | 01:12 PM
shiaochiu's Avatar
well i reset it with the fuse thing.. and the cel went away... i think the computer flipped out because of the change of air coming in...? who knows.
Old Jan 17, 2004 | 03:04 PM
YOD88's Avatar
faqs section is under the start button(top left of screen), incase you haven't found out yet...
Old Jan 17, 2004 | 03:27 PM
3ngin33r1's Avatar
it's also in the notes of the S2000 Talk forum.
Old Jan 17, 2004 | 03:50 PM
JasonX82's Avatar
Unplug the Car battery for a few seconds. that does it for me
Old Jan 17, 2004 | 10:15 PM
shiaochiu's Avatar
well reset the ecu.. cel went off drove around.. turned it off.. then started it again.. CEL again. guess im goin to honda.. :/ i bet its a vacumm hose loose or somethin.. since the valve is on in the right direction
