How do you know when the battery is dead?
Began having similar experience with MY04; slow to crank in winter. I took a look at the battery fluid level window in the top of the OEM Panasonic battery and it appeared low (even though this is supposed to be a sealed-style battery). I bought a bottle of distilled water at the grocery store and slowly filled to the 'full' ring indicator at the base of the screw-off battery cap. I then hooked a half-amp charger to the battery for 36 hours. I have not had any more problems since then. This is in an 18,000 mile S that is garaged all winter.
Originally Posted by Ks320,Apr 22 2009, 06:34 AM
except a battery in Hong Kong costs nearly 900 USD
Can get cheapo ones for around 100 USD. Not sure why the original OEM one is 900 USD, it's a bit absurd ...
If you have to get one, I would go with an aftermarket replacement.
I've had good luck with dry cell batteries like Optima or Odyssey. I routinely replace the OEM battery at the 4 - 5 year mark, even if it load tests OK I'd rather not take the chance vibration may cause a mechanical problem with the plates. Cheap insurance IMO, I once had a battery totally die late one night on a date at a "scenic location".
it
