How Do you Prevent your Radio Antenna From Being Bent Under a Car Cover?
Old Feb 4, 2014 | 09:14 PM
na2king's Avatar
Default How Do you Prevent your Radio Antenna From Being Bent Under a Car Cover?
i am thinking Styrofoam but what do you guys do?
my antenna looks bent and limp like a old man's wet noodle
Old Feb 4, 2014 | 09:30 PM
sillyboybmxer's Avatar
take it off first??? or buy an oem cover with the slot for it
Old Feb 4, 2014 | 09:31 PM
zdave87's Avatar
Member
Unscrew it and take it off.
Old Feb 4, 2014 | 10:11 PM
IrishCarBomb's Avatar
Make a small hole in the cover
Old Feb 5, 2014 | 03:35 AM
redlineracing's Avatar
Most good quality car covers have a "sock" for it.
I use a CoverKing Silverguard cover on my 03.Works great!
\rlr
Carolina
Attached Thumbnails How Do you Prevent your Radio Antenna From Being Bent Under a Car Cover?-s2k.jpg
Old Feb 5, 2014 | 04:33 AM
92gli's Avatar
Give it viagra
Old Feb 5, 2014 | 04:52 AM
Needsmorepower!'s Avatar
Originally Posted by 92gli
Give it viagra
This.... my best solution was to replace the oem antenna with a 2.5" billet antenna... other than that. Cutting a little spot out would work, the oem cover is designed with the antenna to have a pocket and so are true-fitted car covers. Alll good options.
zeroptzero's Avatar
They are ugly and they eventually go limp , get a shorty metal antenna. My oem car cover has a sock for the antenna.
Old Feb 5, 2014 | 07:33 AM
StormTroopinAP2's Avatar
Speak for yourself. Mine stands tall and erect in all its glory.
Old Feb 5, 2014 | 08:08 AM
cosmomiller's Avatar
Top Answer: 1
You should be at the age where you know how to get things done. When the moment is right for you to cover, you will be ready. Be sure to ask your mechanic if you are ready to cover it. Do not drink excessively if you are going to cover it. You know your car is right for you, be ready.
