View Poll Results: Stock? Modified? How does it run?
Is stock and RUNS GREAT ALL THE TIME...NO PROBLEMS
59.02%
Is modified and RUNS GREAT ALL THE TIME...NO PROBLEMS
29.51%
Is stock and RUNS GREAT MOST OF THE TIME
5.74%
Is modified and RUNS GREAT MOST OF THE TIME
4.10%
Is stock and is a MONEY HOLE..always needing something
0.82%
Is modified and is a MONEY HOLE..always needing something
0%
Is a POS
0.82%
Voters: 122. You may not vote on this poll
How does it Run?
Old Nov 16, 2009 | 02:39 AM
fltsfshr's Avatar
Default How does it Run?
Well?
If you keep reading this forum, you'd think every S in the world has problems. You never hear from the ones running fine.
So I thought a POLL was in order.
Mine runs fine all the time and it's heavily modified.
I think I got it right.
fltsfshr
Old Nov 16, 2009 | 03:30 AM
Swang's Avatar
im running fine with intake
i was even running fine with an intake and r1000
some ppl need get the driver mod perhaps?
Old Nov 16, 2009 | 04:59 AM
takeshi's Avatar
[QUOTE=fltsfshr,Nov 16 2009, 03:39 AM] If you keep reading this forum, you'd think every S in the world has problems.
Old Nov 16, 2009 | 05:23 AM
Saki GT's Avatar
There's a big difference between an intake modded car and a full SC FI modded car.
Old Nov 16, 2009 | 05:58 AM
Mike21's Avatar
bolt-ons won't really affect how a car runs. once you get into FI and internal engine mods is when problems arise.
edit: mine is stock and runs like an ethiopian in a marathon.
Old Nov 16, 2009 | 07:32 AM
PanteraKitty's Avatar
I bought mine with 58,000 miles on it. It now has 87,000 miles. I have torn both front sway bar mounting brackets loose, replaced one clutch, one left rear axle, one heater blower, and it gets a CEL about every 10,000 miles. The CEL is for random misfires so I clean and inspect plugs and coil packs and put it back together and it will be good for another 10,000 miles.
The rear axles start making noise about every 10,000 miles and I have to grease the splines that go through the hub to make it quiet again.
Today it is getting both rear wheel bearings replaced. They got scary loose without ever making any noise.
Is that excessive or just normal maintenance?
Old Nov 16, 2009 | 07:54 AM
dammitjim's Avatar
From what I gather an SC car has a different level of reliability than a turbo car. This is an interesting poll but it would be better if modded was broken up into N/A, SC and turbo.
Old Nov 16, 2009 | 07:55 AM
FitzyS2k's Avatar
I bought my car with 40k and now have 87k and just replaced my plugs and did valve adjustment and the car runs alot better then i ever remember. it pulls strong in the low rpms. the only thing I have done to the engine is a snorkel to the stock airbox. i had a axle replaced under warranty. the car has been great for me.
Old Nov 16, 2009 | 07:56 AM
dammitjim's Avatar
Originally Posted by PanteraKitty,Nov 16 2009, 10:32 AM
Is that excessive?
Depends on the car's track/street ratio.
Old Nov 16, 2009 | 09:48 AM
Clemsons2k's Avatar
Or even heavily modded and lightly modded. My car has a few mods but nothing that should make it run bad or be unreliable.
