How to fix a little jerkiness right after shift?
Lately right after I've been shifting it feels like the tranny, gearbox, or whatever it is goes a little herky-jerky for a quick second or two until I get into the throttle. What's wrong with my technique? I self-diagnosed and fixed my first problem which was the lurching of the car right before shifting - caused by getting off the gas too fast before the clutch went in. So now I ease in the clutch as I ease out the gas, but now after I'm done shifting and I have the car in gear often I get a little bobbing.
Anyone know what I can try?
Just different shifting styles. the higher the RPM, the more they will want to drop when you shift. If you don't want any bumpiness, you'll have to revmatch and apply gas evenly. Otherwise, I think the bumpiness you feel is the clutch being let out and the rpms being adjusted.
The idea is to have the speed of your gearshift and clutchwork match the amount of time it takes for the RPMs to approach the range they would be in the next gear.
The next issue is applying the correct amount of throttle for the amount of acceleration you want, but still factoring in that you need to engage the clutch first then apply the throttle full on.
Remember too, that the factory clutch is not "full on, full off". Depending on how you're driving at the time, you can slip the clutch to smooth the shift if the RPMs are higher than they need to be. Obviously this slippage occurs for just a fraction of a second though.
Taking everything into consideration and "working it" takes a little time to get right.
Don't jerk on the wheel when shifting...
Also...check your tire pressures. The right side should match the left side psi...more than 2-3psi difference between right & left can cause the s2k to jerk a bit. Also make sure the pressure at the rear is at least 28psi...as it gets lower the car can also dance a bit.
Originally Posted by rocrfella,Mar 14 2009, 01:06 PM
you replease the clutch too fast!
its all timing, so just mess around with it and eventually youll find the sweet spot.
