How to launch a s2000
Old Aug 26, 2005 | 10:34 AM
Y2TuCkY's Avatar
Originally Posted by ho2go,Aug 26 2005, 08:59 AM
How does launching at high RPMs reduce stress on the drivetrain? (Unless it's meant to spin the tires for a moment - that would make sense to me.) Thanks!
Yup, it break loose the tires, making it less strain on the diffs.
Old Aug 26, 2005 | 01:04 PM
GeorgeP's Avatar
Not really true. At some point the tires have to hook up. The stress on the drivetrain will be proportional to the acceleration rate of the car. If you get a great launch with rapid accel you put more stress on the drivetrain.
Old Aug 26, 2005 | 01:30 PM
exb00st's Avatar
True, but its more gradual with wheelspin vs. a harder shock to the diff when hooking up instantly.
Old Aug 26, 2005 | 03:32 PM
C4SxM5's Avatar
I always wanted to ask what "launching" a car really entailed, but didn't want to look stupid, so thanks for popping the ?
SO basically, to launch the S2K:
1. Step on the clutch
2. Put it in 1st gear
3. Gas it up to desire RPM and hold (7000 or so)
4. Let go of the clutch pedal as fast as possible and floor it???
I'm not sure if you are suppose to release the clutch slowly before flooring it or just let go of the clutch pedal as fast as possible and get ready to switch gears. Any step-by-step instructions for dummies would be helpful!
jwa4378's Avatar
Read in my above post about the tires catching AFTER interial has started. Parts, especially well tubed ones, tend to want to stay in motion, not screech to a stop.
John
Old Aug 26, 2005 | 03:35 PM
jwa4378's Avatar
I always wanted to ask what "launching" a car really entailed, but didn't want to look stupid, so thanks for popping the ? thumbsup.gif
4. Let go of the clutch pedal as fast as possible and floor it??? confused.gif
Yup. Except on step 4, what I do is side step the clutch. When you depress it, do so with only the right side of your foot (big toe if possible), when at desired RPM, just push your foot off the left side of the pedal. The resistance will pop the clutch up faster than you can let it out. Also good for burnouts .
John
Old Aug 26, 2005 | 03:42 PM
C4SxM5's Avatar
John
OOOO! So basically when you are at your desired RPM, use only the side of your clutch foot keep the clutch pedal down and QUICKLY slide it off when you are ready to take off?
I'm really going to try some of these techniques tonight, so any input would be helpful!
thanks
Old Aug 26, 2005 | 05:09 PM
jwa4378's Avatar
make sure you are in an OPEN area. If you try to counter steer, and the wheels lock up, get ready for some head-snapping oversteer. If you feel like it is getting away from you, get on the clutch IMMEDIATELY, or just get off the gas ASAP.
John
Old Aug 26, 2005 | 05:52 PM
Wisconsin S2k's Avatar
Originally Posted by GeorgeP,Aug 26 2005, 07:14 AM
The result of this is that its not a very good drag car and can become very expensive fast when you use it in a manner it was not intended.
Regardless of what the car was intended for or what it's forte is, there is NOTHING wrong with drag racing it. If the car wasn't as fast as it is in a straight line, it would not be as good a contender in the handling department.
If you want to drag a roadster pick up a 98 or 99 BMW Z3M with the S52 240HP engine. Its quicker then the S2000 stock
..... the S2000 is faster than the Z3
If you drag your S2000 get your checkbook out and ready for the repairs.
this has as much relevance as "if you redline your S2000 and corner hard with it, get your checkbook out and ready for repairs"
Also please don't try and scam Honda with warranty claims from racing. It makes it that much harder for the rest of us to get our cars fixed when we have legitimate problems!
Old Aug 26, 2005 | 06:00 PM
not true. while your tires are spinning, the diff and drivetrain are not suffering the full load and weight of the entire car they normally would if the tires and clutch had caught instantly from a short launch and WOT acceleration.
