How low should I drop
Old Oct 16, 2006 | 02:32 PM
Clean's Avatar
Default How low should I drop
I ordered an amuse style front lip and I think once it is on, the car will need to be lowered. I don't know how much it should be dropped because I have stock wheels and if it is too aggressive it will look bad. I have decided I just want to get short springs so what do you think will look the best? It is a Silverstone MY03.
I don't know if i should drop it 1 in or .6 in. Any comments or suggestions are welcome, hopefully from someone who has lowering springs.
Old Oct 16, 2006 | 02:46 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Don't drop miore than 1".
If you wanna keep the handling characteristics of the S,get some good quality springs,Swift or Eibach,and a set of Koni.
Old Oct 16, 2006 | 04:25 PM
Enthralled's Avatar
I say go for 1" anything less would be a waste....no point in lowering if you don't.I'm lowered on some H&R ajustables and i'm almost flush no scraping problems and i don't have a lip.
peace
Old Oct 16, 2006 | 05:01 PM
Tugz_S2K's Avatar
Banned
pimp slam it 4 inches.... ....
Old Oct 16, 2006 | 05:20 PM
Calgarian's Avatar
Even with Eibachs you'll have to be very careful not to rub the front spoiler. I had an amuse and it was a pain in the neck.
Old Oct 16, 2006 | 06:03 PM
Clean's Avatar
so do you think it would look alright with the front lip at stock ride height?
Old Oct 16, 2006 | 07:14 PM
wanabe's Avatar
dropped mine an inch on eibachs and the fronts rub on bumps and the front end scrapes without a lip if i am not careful-
Old Oct 16, 2006 | 09:00 PM
Bionic Man's Avatar
It will look fine after the front lip is installed at stock height. But.....it will look better with a mild 1" drop. You just have to learn to go in and out of driveways and entryways at an angle to avoid rubbing. Most likely the drop will lead you to get some nice afrermarket wheels. Then you will be very pleased with your new look! Good luck with your decision.
Old Oct 16, 2006 | 09:13 PM
krazyguy316's Avatar
i love the way it looks without lowering it. But i just order springs so i will see what i will have to say about it once its lowered. 1 inch is enough i say. Since i switch to the 06 rims lol
Old Oct 17, 2006 | 03:42 AM
1" drop,on Kg/Mm,+ Konis:
