How to lower top manually without power?
So my car is in pieces, battery is also out of the car with the ground and power cables and I need to be able to lower and raise my top to take my seats out and have more room to work. I've searched around and can't find anything that is useful. Anybody know how to raise and lower the top fast without removing the motors?
Sent from my SGH-T999 using Tapatalk 2
I believe it's in your manual, you just have to disconnect the power cable going to the motors so that they don't put up resistance as you manually lower it.
https://i.imgur.com/IgY31Vf.png
I also tried to move my top manually the other day, except I was pulling it up to get clearance to remove the tray. I was only able to pull it up a few inches. I had to dig my battery out of storage and do it that way.
-Mike
-Mike
im starting to think the top cannot be moved up or down manually. any other ideas on this? the above instructions deal with a my09 and maybe others but not a my05 which is what i have. hope somebody has done this and can share. i tried disconnecting te power to motor but there isnt any power to the motor when the ignition is off.
abroke1
abroke1
Is there no disable switch? When one of the motors on my Eclipse started going out I was able to swith off the power top. It was a bit of a job raising and lowering, but worked
Sent by carrier pigeon
