How to lower top manually without power?
Old Jul 26, 2014 | 07:43 PM
abroke1's Avatar
Originally Posted by toekneer
Is there no disable switch? When one of the motors on my Eclipse started going out I was able to swith off the power top. It was a bit of a job raising and lowering, but worked
Sent by carrier pigeon
I think the manual mentions disconnecting the power supply then should be able to do it. I guess may\ybe a two man job. i sure cant do it by myself. i like the eclipse idea of a simple disable switch
i will just get an extra fuse and note where it goes also hope i dont need it.
thanks for the response
abroke1
Old Jul 26, 2014 | 07:45 PM
Fokker's Avatar
Even without power, the motors provide significant resistance. They're pretty easy to remove even with the top installed.
Old Jul 27, 2014 | 11:48 AM
GravyRobber's Avatar
With the motors removed, is it pretty easy to move manually (like a Miata)? I gutted my top a couple years ago and just go with a removable hardtop. But if I decide to ever put the soft top back in, I'd like to ditch the motors and just go manually...
Old Aug 1, 2014 | 12:36 AM
stupkid's Avatar
It's more of a 2 man job with the power disconnected. You can do it alone but it will just some time and more sweat. I have moved it up and down many times without power ever since this thread. Needed help every time.
zherbo
Jul 27, 2010 08:42 PM
VegaS2k
May 13, 2010 11:11 AM
BlueDevil34
Nov 17, 2005 01:06 PM
owenxguo
Oct 26, 2004 06:44 PM
