How much does using the A/C effect power?
Old Nov 14, 2002 | 09:21 AM
amartin's Avatar
I don't think the AC compressor shuts down on WOT on the S2000... Actually, I wish it did.. But I'm 95% certain it doesn't.
-- Aaron
Old Nov 14, 2002 | 09:44 AM
schwett's Avatar
not really true, afaik, because the serpentine belt is still turning parts of the assembly... the pulley and so on. if you removed it completely, that very small parasitic loss would also be removed. but having the feature does eat a teensy bit of power even when it's off, right?
Originally posted by Destiny2002
When it's shut off, it draws 0 hp.
Old Nov 14, 2002 | 03:37 PM
modifry's Avatar
Honorary Member
This should be simple to test with 2 cars and some level road. Make a couple runs side-by-side, both cars with AC off to get a feel for how evenly matched the cars are. Then, on whichever car is faster, make a few runs with the AC ON, and see what the difference is.
Five or six runs may be enough to see if there's a difference. You might get more consistent results if you do something like run from 50-90 in third gear, so as to eliminate shifting differences.
Old Nov 14, 2002 | 03:56 PM
Elizer's Avatar
from a line the affects of the a/c will be felt, but only slightly, but when you are rolling at a good RPM there'll be only like 3 hp loss
a/c really affects turbo and supercharged cars
but the larger the engine the less it affects it, i.e v6 v8
thanks Auto tech teacher
Old Nov 14, 2002 | 05:45 PM
Destiny2002's Avatar
When I said 5 hp, I rounded up. When I said 0 hp, I rounded down.
The parasitic loss of turning the compressor pulley at a constant speed is hardly significant, maybe adds a tiny bit of rotational inertia to overcome when the engine speed is increased or decreased.
Old Nov 15, 2002 | 07:41 AM
NEPA_S2k's Avatar
Someone could shunt a test light into the circuit temporarily - just see if there's voltage at the clutch at WOT.... then we'll have this burning issue resolved!
Old Nov 15, 2002 | 08:04 AM
Just drive at WOT for 10 minutes and see how hot it gets inside
Kekoa
32
Oct 1, 2003 04:23 PM
Ubetit
Aug 15, 2003 04:41 PM
Brett
Apr 4, 2001 06:32 AM
