How to recover from Hydroplaning?
Old Nov 13, 2003 | 09:59 AM
Drunken_Monk's Avatar
Default How to recover from Hydroplaning?
Is there any way to recover once your car has lost its traction when say going down the freeway?
I thought this would be a good post since all the heavy rain in my area just started?
I would assume that just taking your foot off the gas would slow the car down enough to regain its traction?...
Old Nov 13, 2003 | 10:01 AM
The Gasman's Avatar
I forget if it's different with ABS, but typically you are not supposed to use the brakes but rather try to keep the car in a straight line until the car slows to a point where the tires will grip again.
Old Nov 13, 2003 | 10:03 AM
DeluxeS2k's Avatar
just brace yourself and hope you won't run into anyone. I've had 3 incidents in the past year. I've learned my lesson. Slow down when it rains
Old Nov 13, 2003 | 10:04 AM
rallykid's Avatar
Let off the gas, don't touch the brakes. keep the wheels straight, pray. After you regain control, change your underwear.
Old Nov 13, 2003 | 10:08 AM
wanabe's Avatar
and steer with the rear...
if the left side end is coming around, steer into it (steer to the left).
Old Nov 13, 2003 | 10:32 AM
xviper's Avatar
If you have already achieved hydroplaning, you will have NO brakes, NO steering. The best you can hope for is to let the resistance of the water slow the vehicle down. If the car begins to "yaw" (stop pointing in the direction of travel), you are best to turn the steering wheel so it continues to point in the direction of travel for when you do regain road contact. If it's a long stretch that is pooled with water, then best to push the clutch in to disengage power - 1st so as to not continue powering the drive wheels, 2nd so there is no engine braking when the hydroplaning stops. Continue to slow to a speed where it is safe to re-engage power. If you begin to spin immediately, grab the steering wheel firmly, fingers and thumbs out of the way of the airbag cover, lean back in the seat so your seat belt can take up any slack and KISS YOUR A$$ GOODBYE!
Old Nov 13, 2003 | 10:40 AM
junkyard dawg's Avatar
Gotta agree with xviper. There is no control once you get spinning, which I did immediately. Went across 4 lanes of highway before a retaining wall stopped me. Never hit the brakes till the wall was coming at me head on, then the car spun and I hit rear first. The brake disk was in the road in 3 pie shaped pieces. The dealer told me I would not have busted up the disk if I had not hit the brakes. He wasn't behind the wheel when the wall was a few feet from my front-end though.
Old Nov 13, 2003 | 10:41 AM
BlueIrishS2k's Avatar
[QUOTE]Originally posted by xviper
Old Nov 13, 2003 | 12:27 PM
Smokee's Avatar
Of course you do not drive with cruise control on in those kind of conditions. I'll bet some of you didn't even know the car came with cruise.
Old Nov 13, 2003 | 12:49 PM
stockae92's Avatar
good to know but definitely not something i want to try
