how to use clutch
for me, if the stop will be longer than about 20 seconds, put it into neutral and let the clutch out.. otherwise, in 1st gear and clutch disengauged..
also, shift reasonably rapidly and the engine will be at the almost perfect rpm for the next gear when upshifting.. downshifting if you revmatch requires more skill..
correct me if I'm wrong here, but the throwout bearing goes around the input shaft, and your clutch arm, (which goes in and out to ingage/disengage your clutch) rides on this. When you hold your clutch pedal down, the throwout bearing slides down the input shaft and pushes down on the clutch fingers disengaging it. As long as you hold the pedal down that bearing is spinning. That's why people tell you it will wear out more. I had a 90 Acura Legend with 175k miles on it and had to replace the throwout bearing because it would make a funny humming noise sometimes. The clutch was surprisingly still in great shape, but I replaced it as well.
Just something to think about.
Drive Safe,
Steve R.
Originally posted by rickycrx
Uhh.... disengaged means that the clutch pedal is pressed down...
When you 'engage' the clutch, you are releasing the pedal, engaging the clutch to the flywheel/pressure plate.
Yep, I was following his logic not his words and I made the same mistake. When there is no gear selected and the clutch pedal it out I consider it disengaged, but you are correct.
