HP vs weight reduction calculation
Old Jul 26, 2008 | 09:40 AM
Harpoon's Avatar
Default HP vs weight reduction calculation
What is the rough estimate of how much hp you would need to increase to equal reducing weight in the car?
For example, if you remove the spare, you save twenty or so pounds. How much hp would you have to add to the car for it to feel the same as removing the twenty pounds?
Old Jul 26, 2008 | 09:42 AM
Seattle2k's Avatar
I think i remember hearing 1hp per 5 lbs.
Old Jul 26, 2008 | 10:36 AM
shotiable's Avatar
so i gained 4 hp from removing my spare tire? sounds a bit too much
Old Jul 26, 2008 | 10:46 AM
Rubn1out4GudLuk's Avatar
I heard that it was 1 hp per 10 pounds...I knew someone back in high school that had about 170 pounds of aftermarket sound system in his '90 integra and one day took it all out and somehow figured out that he gained a difference of about 16 or 17 hp from loss of the weight of his system(he didn't actually get more hp but to him it felt like it did in straight line and handling performance, mostly straight line though).
I just stuck with the 1 hp per 10 pounds theory since then.
Old Jul 26, 2008 | 10:50 AM
Terror's Avatar
I believe it is also 1hp for every 10lbs.
Old Jul 26, 2008 | 10:56 AM
Balance_Point's Avatar
This is a fairly accurate guideline-
17.68 pounds of weight removed from the car we should gain about 1hp.
18.12 pounds of weight removed we should have an increase of about 1 lb. ft. torque.
Old Jul 26, 2008 | 12:15 PM
ZDan's Avatar
Just calculate power/weight, no biggie AT ALL!
S2000 weight with driver ~3000 lb.
S2000 power = 237
12.7 lb/hp
Losing 12.7 lb. would be approximately the same as gaining one horsepower as far as straightline acceleration goes.
Old Jul 26, 2008 | 01:25 PM
Vik2000's Avatar
diet is ur best weight reduction trust me lol.
Old Jul 26, 2008 | 01:29 PM
ace123's Avatar
S2000 power = 237
12.7 lb/hp
yep. thats it.
note that it depends on the car.
Old Jul 26, 2008 | 01:59 PM
flight240's Avatar
working on that right now. x]
