Huge Problem... Car too low (dropped)
Old Nov 20, 2008 | 01:32 PM
KreativS2K's Avatar
Default Huge Problem... Car too low (dropped)
Hello guys. I don't know where to post this. If its not in the right place mods feel free to move it. Anyways I've bought my S2k like 2 weeks ago. It has rims and it is drop, don't know how many inches. My problems is everytime i go over speed bumps or places that have little ramps(little uphill), to get in the shopping my car hits the ground. And i'm not liking it, i feel like i am going to mess up my car. I really try to drive it as low as possible but since im a rookie driver still sometimes i cannot control hitting it. Any of you have this same problem??
Old Nov 20, 2008 | 01:35 PM
Stealth_SUX_'s Avatar
raise it up.
Old Nov 20, 2008 | 01:37 PM
KreativS2K's Avatar
Originally Posted by Stealth_SUX_,Nov 20 2008, 02:35 PM
raise it up.
i want to but right now i don't have the money, and the coilovers that it has are not adjustable i think.
edit : here is a pic.
Old Nov 20, 2008 | 01:39 PM
ace123's Avatar
If you drive at a 45 degree angle really slowly, it helps reduce scraping dramatically on most bumps/dips. Depends on the bump/dip and how low you are, but it works often.
Sinji's Avatar
ive never heard of an un-adjustable height coilover...
Old Nov 20, 2008 | 01:41 PM
KreativS2K's Avatar
i mean springs.. anyways I've uploaded a pic on the second post
Old Nov 20, 2008 | 01:47 PM
S14 to S2k's Avatar
wtf that thing is basically stock height. are you going from a huge SUV to this car or something? i dono how low stock s2000's are but i doubt it's lower than my car. basically you have to change your driving habit...avoid any pot holes, slow down to like 0 mph on speed bumps and try to only go on it with 1 wheel or go around it when you're going up a driveway you have to angle your car so 1 wheel goes up first. same goes for backing out. and some driveways, forget about it.
my car is 4 fingers off the ground...i can clear almost everything...so i think the only thing you can change is your driving habit and drive carefully. good luck hope you don't damage anything.
MyEeek's Avatar
It looks like your tires are the wrong sizes, too much low-profile. I'm assuming you have 17" wheels. If so, I suggest you get 215/45 245/40 size tires. This will make your car a bit higher and look better.
Old Nov 20, 2008 | 01:50 PM
newnan-s2k's Avatar
where r u located????i got your fix trade me for my stock springs
Old Nov 20, 2008 | 01:53 PM
...'s Avatar
yea it def. looks like its the tires go with MyEeeks tire specs and im pretty sure u'll be fine.
