I scraped my mag, help!!
Scraped my mag on the outer edge while going around a concrete curb. How do I fix it or should I take it to a pro? It looks like it's solid aluminum and could be filed down.
Thanks in advance for the help.
I did the same thing ones... If its just on the edge, you can use a dremel tool w/the sanding pads then follow up with the Dremel 'gun metal polish' kit ($9.95)...which has buffers+metal compound.
Actually, you don't even need to 'buff' it with the gun-metal polish kit, unless your just anal (like me)... but it comes out such that you need to be 18" or closer to even see it.
-- Aaron
-- Aaron
Well... I gave you the 'cheap' route... the next step is having it done professionally... REMEMBER you can buy a new rim for about 160bucks from H-n-A... SOOO... don't go crazy on spending major $$ repairing it... Besides, the Dremel look should be "good" until you have enough $$ to fix it right...
$.02,
Aaron
$.02,
Aaron
Originally posted by amartin
.......REMEMBER you can buy a new rim for about 160bucks from H-n-A...
wheels at HandA
