Imagine this Engine in the S2000.... (S2400)
5252 is a conversion factor that comes from the somewhat arbitrary definition of "horsepower" as the unit of power, and using rpm as the engine speed. If they'd used N-m and kW to define the power and torque output, you'd have a different factor.
Great little video, though. If you think the sound is impressive, wait until you hear them in person.
Originally Posted by shotiable,May 24 2007, 09:26 PM
this may be a stupid question, and totally unrelated to the topic, but can someone please tell me when 5252 comes from? my physics teacher and i couldnt figure it out
Engineers usually simplify equation to fit "real" life problems>
**EXPERIENcE**
Originally Posted by __redruM,May 24 2007, 06:16 PM
Imaging electronically opened valves. Not only would this give you the perfiect cam durations and angles for every rpm, but without a valvetrain to spin the redline goes way up. I'd guess this is the future.
In all honesty, I don't think this would do much for increasing rpms. I was under the impression that the forces of back and forth movement on the pistons and rods were the primary limiter.
2 stroke motors get a much higher redline, and no valve train. Part of the issue with 4 stroke is the piston and the valves. If the piston moves faster than the valve spring, then you have issues. The motor that is mentioned in/by the OP has pnematic valve springs. Part of the reason they get up to 19000 is the pnematic valve springs close quicker.
Though I do believe some form of electronic valve train has to be the future. VTEC is a step in this direction, since the ECU decides when to engage the extra valves. But with full control the ECU could give you the cam profile of the most efficient civic at 1/4 throttle and a drag car cam at 100% throttle.
JustJustin
Jun 14, 2004 07:10 PM
