Importing S2000 from USA to Canada---help needed
Old Mar 29, 2008 | 05:38 PM
5abi's Avatar
Default Importing S2000 from USA to Canada---help needed
i know i have to get daytime running lights installed. anything else? honda recall letter--is it easy to get? thanks
Old Mar 29, 2008 | 06:53 PM
Kremlin's Avatar
Yes letter is easy to get. That's all.
Old Mar 29, 2008 | 08:40 PM
neeman77's Avatar
Yes you will need the daytime running lights installed. I just wired ignition to the power source for my HID's. That was the easiest way. He turned on the car checked them and turned it off. I immediately disconnected it and passed the inspection. If you dont get the letter you can register the car on honda.com and get all the recal information from there. That is what I had to do because the previous owner told honda that he was selling the car to a canadian citizen and they would not give him the recall letter at that point.
Old Mar 30, 2008 | 11:02 AM
Kremlin's Avatar
neeman, someone else wired up my HIDs as you indicated for me and for the life of me I can't figure out how to undo it now. I don't have any wiring diagrams. Do you have any pictures of which wires would be connected for this?
Thanks
Old Mar 30, 2008 | 11:32 AM
neeman77's Avatar
It depends where he took ignition from, I took it right from the ecu. You could look for a wire coming right from the ecu going into the engine bay through the firewall. I wired right into the wires going into the little holes beside either fender I forget the colour of them but I can check. The easiest is to look for an added wire on your ecu harness that goes out through the little hole on your firewall and then follow that wire to remove it. Dont forget to put electrical tape over the removed connections.
Old Mar 30, 2008 | 03:07 PM
5abi's Avatar
i dont need to change the speedo or get that child restraint thing?
Old Mar 30, 2008 | 03:12 PM
neeman77's Avatar
no the speedo is digital you just hold down the button on the cluster for 5 seconds and it changes to KM/H. Also, convertibles are exempt from the child restraint requirements. All you will need is the DRL's.
Old Mar 30, 2008 | 08:58 PM
Saki GT's Avatar
What does it take to import an S2000 from Canada to the USA?
Old Mar 31, 2008 | 09:18 AM
neeman77's Avatar
I dont think the vehicle needs to be modified at all to take from Canada to USA. Same process of obtaining recall clearance letter from Honda Canada, ownerships and bill of sale I would assume.
Old Mar 31, 2008 | 11:27 AM
detonator2x's Avatar
Drive across the border!
