installed rick's badge
Old May 16, 2001 | 07:12 PM
wanabe's Avatar
silver on black on my black car- so far rear only. that one took about 45 minutes... maybe because i have the "upgraded" black "H" emblems. guessing that they have more surface than the originals. the look is subtle...
am thinking about putting red on black on the front.
the one hint that i would add is that the floss should be at least doubled while removing the old badge.
i did notice that the dealer scratched up my car (under the badge) when they installed the black emblems. was surprised that i would do a better job than they would!
i would like to be able to change emblems...
rick, or anyone-
where can i get replacement stuff (and what do i get?) to stick the emblems back on when i take them off and remove the sticky part?
Old May 17, 2001 | 08:59 AM
wanabe's Avatar
really, no one knows what adhesive i need to buy to mount the badges (after they have been removed once before)?
Old May 17, 2001 | 11:30 AM
S2K Fan's Avatar
3M tape, the same kinda body shops use.
Old May 17, 2001 | 02:07 PM
wanabe's Avatar
thanks m! at any auto parts store i assume?
Old May 26, 2001 | 08:53 AM
wanabe's Avatar
a few more installation hints:
1. double up the floss
2. try dry removal... worked better for me and was not as messy
3. if you have the black chrome H badges, they are probably not clipped on the back and probably are clipped on the front. may be an easier way to remove, but i just pulled until the clips (and badge posts) broke off (got that idea from this board).
4. mark the center of the old badge on the tape (top and bottom) with a pen. this made exact installation easier for me.
note that the rick badges can be moved if you mess up, as long as you do not press them down first. i did not properly center the front one and was able to remove it and reset it- perfect now!
took 45 minutes to take off the rear badge (they used more adhesive on that one and i used solvents which made the job messy); 5 minutes to loosen the front, but about a half-hour (mainly trying to figure out what to do) to remove the front.
installation (putting the new badge on) takes 30 seconds!
and these badges are awesome!!!
THANKS RICK!!
Jamie_Murray
Oct 20, 2007 06:58 AM
ThatllHappen
Oct 15, 2006 05:57 PM
Garyj
Sep 30, 2001 03:57 PM
The Captain
Aug 4, 2001 08:17 PM
wanabe
May 30, 2001 01:25 PM
