Invidia exhaust
Old Jul 8, 2009 | 04:54 AM
Addictuned S2K's Avatar
Default Invidia exhaust
I have an invidia coming soon (used) that has the silencers in it and alil scratched from use. Some help and advice with taking the silencers out and then how to shine it up would help greatly! also this had the honda midpipe welded on do delete some drone the invidia is known for.... any comments on that?
Thanks in advance
Addictuned s2k
Old Jul 8, 2009 | 05:06 AM
Snowmoto125's Avatar
The only thing that helps with drone is a test pipe; with removing the silencers just keep them off. They restrict the exhaust flow.
Old Jul 8, 2009 | 05:15 AM
the exhaust already had that pipe welded on tho. I have a test pipe on my car now with the stock exhaust.
Old Jul 8, 2009 | 07:32 AM
SiCK HONDA's Avatar
The test pipe + honda midpipe SHOULD help the drone dramatically...
Since you haven't and won't drive it without these things, you will probably still think it is VERY LOUD, as you're used to the stock exhaust.
Old Jul 8, 2009 | 01:17 PM
make sense.... so any info on getting the silencers out? he said he was having a hard time... i havnt seen it yet so i dont even know where to start.
Old Jul 8, 2009 | 01:37 PM
DDonovan's Avatar
Wow my silencers fell out..., I never put them back.
Old Jul 8, 2009 | 01:40 PM
05APdeuce's Avatar
silencer is held in by two screws. once you get the exhaust you will know exactly how to get them out.
Old Jul 8, 2009 | 01:42 PM
08YellowCR's Avatar
There should just be a bolt that holds them in should be a easy fix
Old Jul 8, 2009 | 03:48 PM
CKit's Avatar
It's a tight fit with the silencer(s). I'm assuming you mean an Invidia dual because you said silencerS.
If they've corroded a little, they can get a little stuck. I've heard of people undoing the retaining screw, parking in an open area, and blowing them out by revving....
Old Jul 8, 2009 | 03:54 PM
zzziippyyy's Avatar
Ahh did you buy Hardtotops invidia?
