Jack That Actually Works?
Was swapping the exhaust the other day, and found out that all the jacks in the house (we have like 3), only ONE is small enough to reach the front and rear jacking points.
Unfortunately, this one jack is also the crappiest one that takes like 100+ pumps to get the car up to the minimum height for jack stands.
What are some good jacks that work FAST? I don't wanna waste time pumping away just to get the car up!
My car is bone stock suspension wise, so it's not lowered or anything.
Craftsman has an aluminum jack that can fit under even lowered S2000's and I can raise mine with it in about 5 pumps.
http://www.sears.com/shc/s/p_10153_12605_00950239000P
Torin jacks are always good, you can get the cheap harbor freight they work, and there are multiple craftman jacks that are available that work fine.
My friend has the nicest craftsman jack I have ever seen I think it cost $300 but you can pump it up with your foot to make contact and then use the handle to lift the car in about 10 seconds.
I have this inexpensive low profile jack from Sears. It'll get under the sides easily, but it does take more than 3 pumps to get it up! (and that IS what she said)
http://www.sears.com/shc/s/p_10153_12605_0...3&blockType=L13
