J's Tsuchinoko install problems
Old May 16, 2007 | 05:15 AM
^AnDre^'s Avatar
Default J's Tsuchinoko install problems
Ok ive read and read on this site before I picked up my J's Tsuchinoko intake that the front of the engine bay hood needs to be cut. I cut it out. But the F&%@er still wont close. It appears that the air chamber is hitting the hood and requires to be trimed as well, which means I will loose the stock hood support mount hole.
Without my knowledge, my mechanic trimmed that section as well and still we are having issues with the hood closing. When I went back we tried messing around with the hood latch and rubber mounts, but still having issues. You have to quite firmly press down on the hood to close it and even then it still feels like the air duct is touching the hood (there is a grease line which keeps rubbing off onto the air duct).
Has anyone had similar issues and what do I do now to fix it?
Old May 16, 2007 | 05:33 AM
Psilos's Avatar
Tsuchinoko air chamber hits my hood also but I didn't trim it.
Previous owner (I got it used) told me I will have to close my hood that way after installation. My mechanic confirmed that.
Old May 16, 2007 | 05:44 AM
GOS2K007's Avatar
Sounds like crappy fitment to a really expensive part.
Old May 16, 2007 | 05:46 AM
^AnDre^'s Avatar
It wouldnt close without trming it, not even forefully. It would buldge at exactly the chamber high point almost 1" if we managed to get the hood closed.
Old May 16, 2007 | 05:57 AM
Psilos's Avatar
[QUOTE=GOS2K007,May 16 2007, 05:44 AM]Sounds like crappy fitment to a really expensive part.
Old May 16, 2007 | 06:25 AM
Psilos's Avatar
1" is too much! My hood doesn't hit the air chamber that much, it only touches it just before closing and then you have to press it gently to close.
Maybe you should check again the position of the snorkle inlet.
In my car there was a protection bar in front of the radiator which had to be removed for the snorkle's installation, but I think US AP1s don't have this.
Old May 16, 2007 | 09:09 AM
HiPER's Avatar
aftermarket hood time?
Old May 16, 2007 | 09:43 AM
^AnDre^'s Avatar
I didnt do any of the installation so I will have to revert back and see what was done.
Im not in the market for an aftermarket hood. I prefer the stock look with everything else inside
As the saying goes... All Go and no Show.
Old May 16, 2007 | 10:04 AM
Invision's Avatar
i also needed to cut that area on the hood because the chamber was touching it. i later went on to a diff intake.
Old May 16, 2007 | 12:35 PM
essess's Avatar
all go? you bought a $1k intake that produces like 5-10hp, why not save that for a sc or a turbo......
just my .02
