K&N FIPK
Old Apr 30, 2007 | 05:12 AM
GOS2K007's Avatar
Default K&N FIPK
I think I am going to purchase one to go with my AUT cooling plate. I did some searching on here and didn't really come up with an answer. I saw where someone with an 06 installed model #63-3514. They had to plug a hole on the tube and drill another hole.
Is there a model made now for the 06-07 that already has this done from K&N?
Old Apr 30, 2007 | 06:13 AM
Rdrcr's Avatar
I have the same FIPK kit on my '06. You don't have to drill any new holes in the tube. Just plug the intake temp sensor into the supplied hole (which had a different use in pre-'06 cars) instead of plugging it up and drilling a new one.
Mike
Old Apr 30, 2007 | 06:21 AM
GOS2K007's Avatar
Mike
Cool, that is what I was thinking when I looked at the thread where the guy drilled a new whole and plugged the other. I was thinking you could just use the one already there.
Thanks
Old Apr 30, 2007 | 08:26 AM
S2K626's Avatar
I installed the same intake on my 06 as well but i remember drilling a hole for the air temp sensor. . . .
Old Apr 30, 2007 | 08:51 AM
Tuanster's Avatar
I guess you could use the "unuse hole" for the 06. But since K&N instruction said to plug that hole and drill the hole for the AIT. I didn't want to take any chance and f***k up the tube. So I drilled.
Old Apr 30, 2007 | 09:42 AM
Dave-ROR's Avatar
I drilled as well, didn't want to deal with sealing that much larger hole with the smaller temp sensor in it, and not getting the sensor in the actual airflow.
Old Apr 30, 2007 | 09:44 AM
GOS2K007's Avatar
I thought it could easily work like this.
Pop the grommit into the bung that is already there.
Old Apr 30, 2007 | 09:46 AM
8kGoodENuff's Avatar
So what size drill bit was used for the new hole?
Andre
Old Apr 30, 2007 | 09:48 AM
GOS2K007's Avatar
Andre
You should not need to drill see above.
Why make another hole in the pipe.
Old Apr 30, 2007 | 10:37 AM
Is it the same size hole in which the sensor will fit ok?
Andre
