Kangarooing and lurching 1st gear?
Old Mar 18, 2019 | 09:04 AM
The King's Avatar
By chance, does your car have an aftermarket air intake? I've heard they can cause the car to do this sometimes because of heat soak quicker than a stock airbox. My car was doing some of this when the map sensor was causing problems.
Old Mar 18, 2019 | 10:06 AM
CryptoPapi2k's Avatar
It's completely stock, I was having some trouble adjusting to the clutch but now i'm getting much better and feeling more comfortable driving it.
Old Mar 18, 2019 | 04:39 PM
rpg51's Avatar
Originally Posted by xxyion
I do however feel that making the car move with just clutch and no throttle seems easier when the car is cold rather than fully warmed up. Once fully warmed i HAVE to use a bit of throttle or else the car shakes and doesnt like it.
I should clarify, my reference to taking off with no throttle is intended as a method of training yourself to have a better feel for the engagement point and general clutch control, not as a normal driving technique.
Old Mar 19, 2019 | 04:41 AM
_valtsu_'s Avatar
This might help: https://www.s2ki.com/forums/s2000-un...-pedal-370792/
Old Mar 19, 2019 | 08:39 AM
xxyion's Avatar
No i understand. However i generally only use this technique in super heavy traffic where i dont want to burn the clutch with excessive throttle when only going 2 mph.
Old Mar 19, 2019 | 03:20 PM
beefystud's Avatar
its sounds the like the previous owner changed the clutch without resurfacing the flywheel.....
Old Mar 20, 2019 | 03:12 AM
rpg51's Avatar
With all due respect, I think you might be getting out ahead of your skis with this. I don't think there is enough information here to reach that conclusion.
Old Mar 20, 2019 | 07:53 AM
Say Chi Sin Lo's Avatar
Old Mar 21, 2019 | 08:47 AM
beefystud's Avatar
Originally Posted by Say Chi Sin Lo
have you ever driven a car where the clutch was changed but the fly wheel had not been resurfaced ? no ? didnt think so ........
Old Mar 21, 2019 | 08:49 AM
Have you ever driven the actual car in this discussion? No? Didn't think so........
Since you like being a keyboard mechanic so much without actually checking out the car, here's another one for you. My car makes a rattle intermittently here, where is it coming from? I'll give you a hint, it's coming from the car.
