Last question about VAFCII install
Old Jun 14, 2007 | 01:06 PM
nightcrawler7188's Avatar
Thumbs up Last question about VAFCII install
UPDATED OP:
am i supposed to be able to reinstall the kick plate after getting the VAFCII harness in and the unit is up and running? the harness takes up too much space so it's physically impossible to put the kick plate back on. am i supposed to leave it off? or rearrange everything so that the harness sits flat against the wall (as of now i don't see how i can do that)?
Old Jun 14, 2007 | 03:35 PM
anyone?
Old Jun 14, 2007 | 05:51 PM
negcamber's Avatar
The largest box behind the kick panel is the ecu. The 3 connectors only fit one way.
Old Jun 14, 2007 | 05:54 PM
THANK YOU. kick panel is that plastic piece that's parallel to the floor of the car?
Old Jun 14, 2007 | 06:12 PM
negcamber's Avatar
The kick panel is the flat panel that makes up the left side of the driver's foot well. It is perpendicular to the floor.
If I recall correctly...you have to remove the door sill plastic trim before you can remove the kick panel. The ecu is mounted to the wall of the footwell with the connectors pointing down.
Old Jun 14, 2007 | 06:18 PM
TheCarGuy2021's Avatar
Take of the little door sill that says "S2000". The kick panel will have the fusebox diagram on it. There are 2 pop rivots holding it on, one at the top, and one by the pedals. You can't miss the ECU from there.
Old Jun 14, 2007 | 07:12 PM
any tips for getting those stubborn plugs out of the ECU??
i got the middle one out but i can't get the other two to budge (i can press the little release button but can't get them to come out).
thanks
Old Jun 14, 2007 | 07:25 PM
negcamber's Avatar
They are buggers...no real trick to it...gotta just keep after them.
Old Jun 14, 2007 | 07:26 PM
do i run the risk of messing one up if i pull too hard or something?
Old Jun 14, 2007 | 08:42 PM
OP edited with my final question (i promise)
