Leaking Tyres
Old Jul 23, 2001 | 11:32 AM
Speedster's Avatar
Default Leaking Tyres
I like to keep my air pressure at around 35 psi, but I've noticed that my left front and right rear tyres will leak down to about 25 psi within a couple of days of inflation. Its very inconvenient as I need only fill up my tank every week or so. Is there something I can do about this?
Cheers,
Edward
Old Jul 23, 2001 | 04:51 PM
elviscos's Avatar
I have a slow leak too in the right rear. I just fill it a bit every morning as it only loses about 1/2 pound per day. Those digital pressure guages are awesome. I have not tried to have anyone find the leak so I don't know where it is. Good luck.
Old Jul 23, 2001 | 06:53 PM
cdelena's Avatar
Yeah, go to the tire shop and get the leak fixed. Tires normally will only lose about one PSI a month.
Old Jul 23, 2001 | 07:46 PM
S2R's Avatar
S2R
If you have aftermarket rims, check the valve stems. You might have to tighten those.
Old Jul 23, 2001 | 11:14 PM
MarkS2K's Avatar
I know I don't have a slow leak in the tires, but mine do this too. I put 33 psi in all the tires and they all seem to drop to 25 within a few weeks. Not sure what's going on. I think it's justthe way the S02's are.
Old Jul 23, 2001 | 11:37 PM
2kturkey's Avatar
My left rear has been losing air at around 2psi per day for the last couple of weeks. I did the valve spittle test and yes that was the problem. After I took the valve out I noticed that the black sealing ring was split almost all the way through
This is the first time I have seen this sort of valve damage in 30 years of driving!
Old Jul 24, 2001 | 07:25 AM
xviper's Avatar
My SO2's don't leak. There's something wrong if they do. You may have a bead leak, a valve leak, or you've picked up a nail or screw in which the head has been worn off and you can't see it. In either case, talk it to a trusted tire shop to have it put in the "dunk tank" or have the soap spray thing done to it. (They'll know what this means.)
pervypete
Feb 19, 2011 05:06 PM
jyeung528
Dec 17, 2003 06:10 AM
rworne
Nov 25, 2003 12:32 PM
Lotusman
May 20, 2002 02:38 AM
Ross
Dec 2, 2001 04:49 AM
