least expensive HID bulb
PM Hardtopguy. He has the best prices. The lighting on the S is very expensive. If you had to replace the entire lighting system you are look at least $1200.
How do you know your bulb is bad Redline? The HID bulbs rarely go bad. Chances are it is a bad inverter which is a little less expensive.
You might want to take the bad bulb out and put it in the side that is good. If the the bad bulb works on the good side you know it is the inverter.
I replaced one inverter last year. Be careful Honda warns that death may occur if you do not follow the correct procedure for working on the lighting system.
Originally posted by Microbomb
I don't think so. From what I have heard it takes a huge amount of voltage/amperage.. or whatever to ignite the gas in the bulbs. I am guessing its similar to how a TV can shock the shite out of you if you open it up and touch a capacitor, but this is only a guess.
its definetly the bulb, i tested at my shop, and you can clearly see the bulb is burnt, HIDs rarley blow, but my headlight had massive water in it................................................ .
