Leave in gear when parked?
Old May 10, 2001 | 09:52 PM
MDS2K's Avatar
My friend told me that its a good idea to leave the car in gear when parked. I am used to putting in neutral so I dont know. Do you guys leave it in gear??? Why?
Old May 10, 2001 | 09:54 PM
ricosuave's Avatar
i usually leave it neutral w/ the emergency brake if on a level ground. otherwise i leave it in 2nd on uphill and reverse on downhill.
Old May 10, 2001 | 09:56 PM
S2000spoon's Avatar
Always in gear....the ebrake get loose after a while....
Old May 10, 2001 | 10:00 PM
PaulS2K's Avatar
I always leave it in gear.
Old May 10, 2001 | 10:08 PM
bentrim's Avatar
I always leave in gear too
Old May 10, 2001 | 10:10 PM
MDS2K's Avatar
Thanks guys!! I better start leaving my car in gear too!!
Old May 10, 2001 | 10:20 PM
Type R 1090's Avatar
On level ground, I just pull the e-brake and leave it in neutral. On a grade, it's either in 1st or Reverse depending on which way I'm facing. Reason for this is in case your e-brake ever gives out, your car won't roll. Make sure you remember you have it in gear when you start the car though, sometimes I forget and THUNK!!! Look like an idiot .
Old May 10, 2001 | 10:50 PM
WoofWoof's Avatar
Also remember to turn the wheel the right way...
Left for uphill, right for downhill...
Old May 10, 2001 | 11:55 PM
lvs2k's Avatar
I don' know about your car, Type R, but mine won't start unless I've got the clutch in, so no "THUNK". Do the cars imported to Canada not have this feature?
[Edited by lvs2k on 05-11-2001 at 12:58 AM]
Old May 11, 2001 | 06:09 AM
Fed's Avatar
Fed
He means, push the clutch down, and start the car in gear, then release the clutch without removing the car out of gear, after that hang on!!!!!!! Did that once too.
