Left Rear Vibration at Highway Speeds - Running Out of Ideas
Old Oct 8, 2021 | 09:13 AM
JoePhotographer's Avatar
Default Left Rear Vibration at Highway Speeds - Running Out of Ideas
A quick synopsis...
Summer of 2020, I started to get a clicking sound in the left rear. Telltale sign of the axle nut. I was near 100,000. So, I replaced the left and right axle nut.
This is when the left rear vibration started.
In my attempt to diagnose it...I did the following
confirmed that the wheel and tires (I have two rear wheel sets (Summer and All-Season) are straight and true. I also swap my Summer tires yearly.
axle spacers on the original OEM axles
aftermarket axles (I still have the OEM axles)
axle bearing (left and right)
Other than the vibration at highway speeds (69-75 MPH is the worst), the car is fine. (the vibration lessens over 75-80)
In this state, I've driven over 30,000, from Ohio to...
Boston Mountains Spring 2021 (Branson, MO)
3000+ miles to Sheppard AFB, TX (Wichita Falls), through the Deep South (MS, AL, LA) TX and western NM (Tucumcari), then back I-40 and I-70 through MO, IL, IN OH.
2 trips to the Tail of the Dragon
S2KDays in Northern Michigan
Also, this is my daily. My other car is a 1985 Porsche 944.
The car just turned 130,000.
I'm running out of ideas on the left rear vibration. I'm sure the Differential is not the culprit. I'm even going the rabbit hole of drivetrain misalignment or motor mount replacement.
I plan to drain the Diff and Trans before Winter.
Anyone? Buhler??
Old Oct 8, 2021 | 09:20 AM
engifineer's Avatar
How certain is it that it is left rear? Many times we think a vibration is on the left because that is the side we sit on. Let a passenger ride along and do not tell them anything but to pay attention to the vibration, they very well may say it feels like it is coming from the right And could be that it is coming from the center of the car as well.
Old Oct 8, 2021 | 09:23 AM
You make a good point. My GF has been in the car (roughly same weight) and we do not notice it on the right side.
Old Oct 9, 2021 | 03:11 PM
MrFunk's Avatar
Have you done an alignment?
Old Oct 10, 2021 | 07:44 AM
starchland's Avatar
Axle bearing as in wheel bearing or diff bearings?
Old Oct 10, 2021 | 01:09 PM
noodels's Avatar
Just put front and rear discs on my bmw because of a vibration ,turned out to be built up rust on mating surface to hub .got it on a rolling road brake tester and showed a very slight issue. Cost me 4 tyres to get to the problem
Old Oct 11, 2021 | 10:18 AM
MrFunk's Avatar
^^ Yeah I was leadng to that with my question asking about alignment...
Rust on hub making wheels not mate to hub straight and clean will cause vibrations.
Old Oct 11, 2021 | 03:50 PM
noodels's Avatar
To add, discs needs removal to inspect for the issue.
Old Oct 15, 2021 | 03:20 AM
Yes. Two, in fact
Wheel (knuckle) bearings, per Bama Dave
@AaronCompNetSys and I did the following yesterday afternoon:
Re-torqued the axle nuts
Did an E-Brake check
We are going down the rabbit hole of motor/transmission mounts. We have not inspected them yet (ran out of time yesterday), but will do so, before ordering.
Old Oct 15, 2021 | 04:00 AM
starchland's Avatar
Originally Posted by JoePhotographer
Yes. Two, in fact
been through it all. 10 years. Beginning to think either the diff or trans
