Limited slip differential
Old Apr 18, 2006 | 06:01 PM
nightcrawler7188's Avatar
Default Limited slip differential
am i having a differential problem since my tires are wearing very unevenly (my right is worn alot more than my left? or is it because of the way i'm driving? i also notice that when i floor it in 1st gear, the car pulls to the right side strongly.
Old Apr 18, 2006 | 06:08 PM
04RioS2k's Avatar
I say get an alignment and see how it does...
Old Apr 18, 2006 | 06:14 PM
xviper's Avatar
Check your tires pressures?
Old Apr 18, 2006 | 06:59 PM
gomarlins3's Avatar
Dang xviper beat me to it!!
Old Apr 18, 2006 | 10:04 PM
Bboy AJ's Avatar
Alignment or tire pressure issue. Check the pressure first and if that's fine, get an alignment done.
Old Apr 19, 2006 | 06:18 AM
Wisconsin S2k's Avatar
has NOTHING to do with your diff or limited slip
Old Apr 19, 2006 | 07:03 AM
Elistan's Avatar
I don't know why you're right rear tire is worn more than your left. I've had the same thing happen to me though, and I suspect that 90-degree righ-hand turns at an intersection creates a larger turning radius difference between the left and right wheels than left-hand turns, and possibly causes more tire slip for that inside right rear tire.
In any case, the pulling to the right during acceleration is because your right rear tire has a smaller circumference then the left. During steady-state driving it can cause accelerated wear on the LSD (hence why you never put the compact spare on the rear) but it also causes the rear wheels to act sort of like a cone when you accelerate and the LSD starts to do its thing. Depending on how worn your rears are, either get a new full set, or just replace the worn one.
Old Apr 19, 2006 | 07:09 AM
vtec9's Avatar
of course he did.. his brain is connected to the S2K nexus. He knows the answer to all questions instantly, and can post to S2Ki telepathically.
Old Apr 19, 2006 | 07:44 AM
Red_Devil's Avatar
Old Apr 19, 2006 | 08:27 AM
Elistan's Avatar
You mean, "it has nothing to do with a DAMAGED diff," because it's certainly because of the diff which is simply doing what it's supposed to do.
ITR
May 16, 2011 07:29 PM
skizzo82
Jul 21, 2008 11:38 AM
petouche
Sep 23, 2005 12:00 PM
petouche
Jun 24, 2003 07:24 AM
Mclaren
Apr 1, 2002 12:14 PM
