Looking for clutch (which one do u have)?
I have purchased the Exedy Racing Clutch from Dave over at Rand D motorsports. It is a sweet set up, but you may want to drum up Yellow Streak as he is already using his Exedy with a S/C application, mine is in the mail! Will update after install. PS. It comes with it's own flywheel also. Pt
[QUOTE]Originally posted by VTECPHIL#6829
[B]I have purchased the Exedy Racing Clutch from Dave over at Rand D motorsports. It is a sweet set up, but you may want to drum up Yellow Streak as he is already using his Exedy with a S/C application, mine is in the mail! Will update after install. PS.
I had an ACT stage 2 clutch & P.P., & machined flywheel installed and out the door for less than $800.00. I must warn you, I believe the s2000 clutch is weak on purpose...to save the drivetrain!!! When you upgrade the clutch, the shock is transferred entirely to the rest of the drivetrain, and it might not hold up! You may be better served to ride the stock clutch out as long as you can.
I have the street ACT and can only say good things about the clutch. The clutch is what honda left out of the car. I didn't changed the flywheel because I do alot of stop and go driving but what a difference.
When you power shift to third just hold on!!!!!
Also the hesitation(bogg) when the stock clutch is released is gone, thank god!!!!!!!!
I have a Star Stage II. I was questioning my decision for the first couple hundred miles, but then it started grabbing better. It just took a little while to break in.
Here's the info on the installation:
http://www.rebelann.com/s2k/
