Lower profile?
Old Feb 26, 2004 | 05:03 PM
blaks2k's Avatar
I know I will be scolded for bringing this to the main forum, but no one is replying on the tire rack forum.
Can you put a lower profile tire on the stock rim? If so, what size? I don't want something that will look ridiculous, just a bit lower.
Thanks!
[yea, I did a search. Someone answer and I'll delete the post!]
Old Feb 26, 2004 | 06:47 PM
Russ's Avatar
The answer is yes but you will get a tire smaller in diameter.
205/50/16
225/45/16
This combo will work but only if you lower the car to close the gap created
by tires .8 inches smaller in diameter. The positive is a quicker car due to your
gear ratio jumping a bit north to around :29
Old Feb 26, 2004 | 07:00 PM
User 101724's Avatar
i have the same question in the tire forum...
i just dropped in a new set of tires and wheels, and noticed the combined wheel & tire diameter has shrunk. is this ok? what side effects? from what i can tell, if you reduce 10mm on the tire, then you should add an inch on the wheel. just want to be sure i dont throw off odometer and speedo too much...
hey russ - i noticed you are running the rota slipstreams and toyo proxes.... that is exactly what i ran on my miata (tho 15"). since im selling it, i moved that setup onto my wifes 03 civic si (which had terrible tires).
here are the wheel/tire sizes:
to: P195/50VR15.0
Old Feb 26, 2004 | 07:20 PM
blaks2k's Avatar
Doh! I don't think I'm willing to lower the car for the smaller profile.
Thanks for the info.
Old Feb 26, 2004 | 08:22 PM
Saint_Spinner's Avatar
Guys, those "extra" miles on your odometer will add up QUICK. Don't do it.
Old Feb 27, 2004 | 04:42 AM
mys2000silvia's Avatar
Im lookin at 245/45 for the rear, and slightly taller for the front.
Old Feb 27, 2004 | 08:27 AM
well, i did my 63 mile commute today with my 10mm shorter tires... i was concerned that the odometer would read like 100 miles or something...
what did it read? 63 miles.
looks like a 10mm difference would be nominal in mileage...
johnfrey_s2k
Jun 15, 2016 12:25 PM
stezie
Nov 9, 2011 10:44 AM
Johnny Sack
Sep 20, 2005 08:32 AM
jwocky
Feb 24, 2005 08:51 AM
alex s
Sep 23, 2004 11:13 PM
