Lowering
Old Mar 16, 2006 | 12:39 PM
Trip's Avatar
Default Lowering
I need to lower car for the simple reason to increase camber.
My goals
Increase as much camber (2.5-3deg)
Remain somehow same softness
Not going too low.
I already had experience with Tein Flex which were hard for daily use even on full soft. I am currently running Koni shocks with OEM springs.
Are there any springs which are as soft as OEM with 1/2 inch lower all round ?
Thanks
Old Mar 16, 2006 | 12:44 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Neuspeed springs.
Old Mar 16, 2006 | 12:58 PM
Trip's Avatar
Originally Posted by Emil St-Hilaire,Mar 16 2006, 11:44 PM
Neuspeed springs.
1.25 Drop
Old Mar 16, 2006 | 01:01 PM
r_duff's Avatar
try tanabe. only .5-.8'' lower.
Have you taken your car to an alignment shop? They should be able to dial it out to 2.5 degrees (dont know why you would ever wanna go beyond that), since the s2k's camber IS adjustable. I think 1.5 degrees is stock on the rear.
Old Mar 16, 2006 | 01:03 PM
mikey k's Avatar
Nitron Sport shocks - you can specify your own spring ratings
www.nitron.co.uk
Gaining credibility in the UK with S drivers and a favourite on Lotus's
Old Mar 16, 2006 | 01:04 PM
Trip's Avatar
Tried many times and only managed to reach around 2deg IIRC.
How are Tanabe stifness ?
Old Mar 16, 2006 | 01:06 PM
r_duff's Avatar
same as stock. i just installed a set for a freind. tanabe even advertises 'just like stock!'
Old Mar 16, 2006 | 01:07 PM
Trip's Avatar
www.nitron.co.uk
I just bought Koni's and i am only looking for springs.
Thanks just the same
Old Mar 16, 2006 | 01:35 PM
Trip's Avatar
Never mind
I just figured it out myself
Koni + lower perch setting =
Old Mar 16, 2006 | 02:10 PM
x s2k x's Avatar
I have Tanabe's and it's almost an inch drop. Plus I went to get my car aligned and i got it around -2.5 at the rears. I really don't know why you cant get more on your car. Have you been into an accident before? Did you hit the curb?
