Lowering springs and stock shocks?
Old Apr 23, 2003 | 07:09 PM
FormerH22a4's Avatar
Default Lowering springs and stock shocks?
How robust are the stock shocks? I am thinking about lowering the car with Eibach springs. Will the stock shocks will wear out fast with the lowering springs?
Also, will the handling characteristics of the S be off after the lowering even if the alignment is good?
Old Apr 23, 2003 | 07:12 PM
Eddie's Avatar
you can get away without changing shocks, just don't lower it more than 1 inch. I've got H&R springs, .75 front .6 rear. they're great
Old Apr 23, 2003 | 08:16 PM
EssTooKayTD's Avatar
from what I've read, as long as you go with progressive springs, you will be ok. You will blow the shocks eventually, but not as fast as if you went with non-progressive springs.
lowering the car should give you better handling, but I've read some stuff about watching out for oversteer with the rear being too low?? might wanna check that out.
Old Apr 23, 2003 | 11:03 PM
Austblue's Avatar
Try a search this topic has been discussed lots and there are some good opinionsbacked up with evidence. eg. https://www.s2ki.com/forums/showthread.php?...threadid=101322
Old Apr 24, 2003 | 04:05 AM
Hobbyholic's Avatar
Definitely go with HR springs they work great.
dthondatune
Jan 16, 2010 07:01 AM
markfromaurora
Dec 8, 2008 05:14 PM
ideugene
Nov 10, 2003 03:35 PM
S2K Mayhem
Jun 24, 2003 05:24 PM
DJHohum
Mar 21, 2001 04:25 PM
